http://en.audionet.de/machines/heisenberg/
кто-нибудь слушал их?
| Output power: | 530 W into 8 Ω
1,050 W into 4 Ω
2,100 W into 2 Ω |
| Frequency response: | 0–700,000 Hz (-3 dB) |
| Damping factor: | > 1,800 @ 10 kHz
> 10,000 @ 100 Hz |
| Harmonic distortion: | k2 typ. -117 dB for 25 W into 4 Ω
k3 typ. -123 dB for 25 W into 4 Ω |
| Intermodulation: | < -110 dB SMPTE 100 Hz : 20 kHz, 4 : 1, 50 W into 4 Ω |
| THD + N: | > -106 dB @ 1 kHz, 25 W to 700 W into 4 Ω |
| SNR: | > 125 dB |
| Filtering capacitance: | 200,000 µF |
| Input impedance: | Line input: 50 kΩ, 33 pF
XLR input: 7 kΩ 66 pF (line to line) |
| Power consumption: | max. 2,400 W |
| Mains: | 220..240 V or 110..120 V, 50..60 Hz |
| Dimensions: | Width 270 mm
Height 500 mm
Depth 490 mm |
| Weight: | 66 kg |
