Фонокорректоры Aesthetix Rhea
http://www.aesthetix.net/rhea.php
У кого такие были? Есть ли смысл в переплате за Rhea Signature? Что можете сказать о звуке и о конструкции?
Three RCA inputs.
Each input has its own gain and loading setting that is saved even when in standby mode or the unit is turned off.
Zero feedback.
40-75dB gain maximum, selectable via front panel or remote control.
9 MC loading settings: 75-47,000 ohms, selectable via front panel or remote control.
Remote control of gain, loading, input switching, mute, and demagnetizer.
Built-in MC cartridge demagnetizer.
Two sets of XLR and two sets of RCA outputs per channel.
All tube amplification and output (10 tubes total).
Full function remote included.
Available in black or silver faceplate.
Rhea is available in three versions: Standard, Signature and Eclipse.
The standard version uses high-grade Rel-Cap polypropylene coupling capacitors. The Signature version uses exotic and expensive coupling capacitors and other critical parts to bring the performance to a higher level.
Это продолжение темы https://www.hi-fi.ru/forum/forum174/topic86596/
